07-02-2009, 07:54 PM | #1 | ||
SKID IT
as above, my au is idleing at 3500rpm what can casue this?
it had aftermarket computer, injectors etc, and is turbo if that makes any diffrence, only been doing it since a changed the head gasket cheers
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
07-02-2009, 08:04 PM | #2 | ||
Smile
Air leak....
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
07-02-2009, 08:06 PM | #3 | ||
SKID IT
thats what i was thinking maybe a vacum leak somewhere
07-02-2009, 08:17 PM | #4 | |||
Smile
07-02-2009, 08:29 PM | #5 | ||
SKID IT
yea that is connected, ill go over it all on monday, the grommet was slightly cracked on pvs but it seals so i dunno
07-02-2009, 08:34 PM | #6 | ||
Smile
Also make sure the throttle body blade os close and the idle speed controller isnt faulty..
07-02-2009, 08:44 PM | #7 | ||
SKID IT
it could be that too, looks like monday is gunna be a pain in the .........
08-02-2009, 12:02 AM | #8 | ||
the only other thing i can think off is make sure your coolant temp sensor is plugged in propperly.
it sits on the driver side right back at the fire wall on the rear off the head.it will chuck in lmp if its not plugged in or broken....
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
08-02-2009, 10:39 AM | #9 | ||
Check your accelerator cable where it sits in the saddle on top of the rocker cover. Might sound stupid, but this is the cause for me, under heavy acceleration it sometimes pulls the outer sleeve of the cable back an inch then jams up against the saddle resulting in higher revs including an idle around the same mark you mentioned. An easy fix would be for me to use a bit of silicone to secure it……. One day
08-02-2009, 10:20 PM | #10 | ||
SKID IT
coolant temp sensor is brand new lol
the cable is fine, ive norrowed it down to the catch can blowing not sucking or vise versa, pumbed it up stocko and runs fine
