Hi how are you all just have a qwik Q does ant one own a ford au series 2 forte and having problems filling their tank from empty or 1/4 full. The problem i have is no matter where i go nor what fuel i use the fookin thing always clicks im at witts end and now am usin a funnel to fill the tank, any response to this would be greatly appreciated . cheers Holden Fan for Eva
Flairs - Truckers Delight
hey mate
don't hold the pump right up in there, let it 'sit' a bit to create an escape for the air. should sort itself ok then.
#3 | |||
lol m8 im not blonde nor a chick have tried all the things sometimes if im ****ed off i get the funnel out of the car and use that im asking if its a design fault or if its normal specially for au's its a good car an all but this is becoming a joke at the bowser i know fuel these days is but cumon ? ![]() |
Rockin '67
Yeah my AU does the same thing too.
At some servo's I can get the the nozzle to sit right and it will fill up but only for a couple of litres. Drives me crazy. I just make sure to not let my car get to low or it will take forever to fill up. I know of other AU's that have the same problem. |
![]() Join Date: Dec 2006
On one of my old Au's a piece inside the filler neck broke off, it was the anti syphon thing behind the ULP flap, thing was hard to fill but it was on LPG so I left it alone until it had a prang and I had to remove the tank.
I changed the filler neck and was good after that |
lol i hear that any ideas i dont wanna have take toit with an axe i was thinkin of just drilling the nozzel sleave out and just having the pipe but it leaves it open for to happen maybe go all out an get a m8 to do it but that will take for ever plus im having the blonde moments at the mo
I miss my wheelbarrow
![]() Join Date: Jan 2005
There is the flap you can see about 30-40mm inside the filler neck, then about another 50-60mm further in, there is a series of vents around a central point that stop a hose going into the tank. These vents will swing open to allow the fuel in but not a solid hose.
To be honest with you, the only real issue I can see you having is if the plastic convoluted vent tube that runs from the right/rear/top of the tank to the filler neck has been crimped or crushed over. Dropping the tank out is not a big job, and you will be able to get a look at the vent line that I mentioned above. Daniel |
rightio old bloke
can't really comment on petrol too much, only put in petrol about 5 times in the past two and a half years
