I had some dramas last night with my XR8, I happened to snap my Passengers side Half Shaft right at the hub. Is there any tricks to getting what is left out of the diff centre?
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
Boost is here!!
Just yank on it mate.
Its gonna be abit hard with nothing left on your end of it though. The extra weight of the hub/brake assembly generally helps.
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
get a welder and attach some kind of handle its broken anyway
I had a crowbar between the ABS Ring and the housing, snapped the ABS ring, Halfshaft hasn't budged. This is proving to be a stubborn bastard to get out.
Boost is here!!
If you cant get a good enough grip on it to give it a good yank, do as Blackers said, weld something onto it to give you like a "T-bar" to pull off.
That is IF you have access to a welder.
No access to a welder, and the CV has come out too, making it harder again. This is becoming bullsh*t, 2 days and I can't get the thing out.
#7 | ||||
Back to Le Frenchy
I'd be looking for another half shaft with a hub attached if I were you, that's what I did when I twisted mine.
Stroking it...
Sounds like the joys of having a lokka in the rear end??
Had: 347ci AU Then: ![]() Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
#9 | |||
Boost is here!!
#10 | ||||
Back to Le Frenchy
#11 | |||
