Old 21-10-2009, 07:33 PM   #1
Windsor220
Now Fordless
Windsor220's Avatar
Default 3.9 diff prices
Ok I rang a couple of places today (WA diff centre and Alfred cove Autos) and was qouted around $1800-1900 for 3.9 gears drive in drive out.. Is this price the norm? I thougt it was a bit steep considering I had an LSD with new bearings fitted to a Falcon a couple of years ago for under a grand.
Does anyone know any places in WA that can do a reasonable price?
Old 21-10-2009, 07:40 PM   #2
StealthAu
A new set of gears is around $600, so you are looking at over a grand in labour and oils
Old 21-10-2009, 07:45 PM   #3
FreddyDUZ747
FreddyDUZ747's Avatar
New gears are between $700-$800.
The other 1000$ will be labour,seals,bearings and setting up the lash(pinion ect),remove and replcace housing,bleed brakes and the fluids.Its around the mark mate.Some places will be cheaper and some will be dearer.
If the place is local and has a good rep then go for it mate,price aint everything.
Whats a reasonable price in your books?
Do you know the labour rates at this place,could give you a better estimate.
These gears can be found in R31 skylines and the 4.11 gears are in the Pintara diffs.You can always get good 2nd hand 4.11s as the Pintaras arent hammered like the Skylines.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2009, 08:02 PM   #4
Windsor220
Now Fordless
Windsor220's Avatar
I knew the job would be over a grand but didnt think it would be bordering on 2.
I didnt realise the gears were that much. Labour would be close to $100 an hour Id say.
Old 21-10-2009, 08:06 PM   #5
FreddyDUZ747
Price is around the mark.
Complete Pintara/Skyline diffs can be had for 200$ max.Theirs youre gears if coin is a factor.
Old 21-10-2009, 08:18 PM   #6
private9
www.TUFFCARPARTS.com
private9's Avatar
Just gotta be careful in finding good ones - pinny/skyline borgy gears can be very whiney!
Old 21-10-2009, 08:28 PM   #7
Windsor220
Now Fordless
Windsor220's Avatar
Yeah im not too keen on getting used gears. I might just put the money towards a supercharger.
Old 21-10-2009, 08:29 PM   #8
UU TS50
T3 TS50 075
UU TS50's Avatar
try street torque in Maddington
mobi 0405345906
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2009, 08:31 PM   #9
KR1STO
Just another mock-up..
KR1STO's Avatar
yeah don't go second hand gears man... a mate did that and they were whiney as hell..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2009, 08:33 PM   #10
StealthAu
Good idea, stay away from the second hand gears. I'd suggest going with 4.11's instead of 3.9's, if you are changing them go all out. even at $2k, the best value go fast mod that you can get.
Old 21-10-2009, 08:59 PM   #11
FreddyDUZ747
Its not always the pinion and gears fault.Setup has a big role in it.
Its funny how someone gets a set of gears out of a car thats done 200,000kms and they made no noise in that car yet when transfered into a different but acceptable housing the wining starts?What does this tell you?
Pinion lash ect is very important and just slapping in gears will never work.
If money is a factor though sourcing a good 2nd hand set should not be shunned upon especially if its going to get the job done at the end of the day.If the gears seem to show signs of meshing ect then dont buy them.How many kms do youre gears have on them now and are they whiney?
Its weird how this is the mod that never gets done as it often really completes the package at hand and puts the power where one would most like,sooner.
But yeah,unles youre prepared to spend 2000$ then theirs only two options.
Leave it or 2nd hand.
Old 21-10-2009, 09:13 PM   #12
Windsor220
Now Fordless
Windsor220's Avatar
mobi 0405345906
Thanks. Have you used them before?
Old 21-10-2009, 09:16 PM   #13
Windsor220
Now Fordless
Windsor220's Avatar
Yeah its a mod I would like to do as the gearing with the 4 spd is rather crappy. Its just for 2k I dont want to fit them and it not do much. Then Im probably going to fork out for a blower. I do have the money I just have to be a bit careful with a mortgage and all.
Old 21-10-2009, 09:21 PM   #14
FreddyDUZ747
I didnt see in youre signature it was auto.Thats a good time and mph for auto and stock gears.With gears and another tune I recon youll snag youre 13 second pass.
A set of 4.11s will blow you away in regards to bang for ya buck.Driven correctly on the street econimy wont suffer much at all.
In perspective a stock xr8 with 4.11 gears will hammer a stock xr8 with extractors and exhaust engines being of equall hp.Thats the bang for ya buck to expect but with you it will be made even more of due to the custom tune.
Ive noticed youve hinted supercharger down the track so id be getting the gears to accommodate that setup,wrong ones will compromise the charger.Positive Displacement or Centri?
Old 21-10-2009, 09:29 PM   #15
UU TS50
T3 TS50 075
UU TS50's Avatar
They done my exhauast last week and i enquired about the diff and i think he said 1500 - 1600
Cheers John
Old 22-10-2009, 04:08 PM   #16
sd1800
If you change to 4.11's, how do you adjust the speedo? Is there a different speedo gear you can put in the box or do you need to use the jaycar adjuster?
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2009, 04:16 PM   #17
Scaffy
Rlegaur Mbemer
Maybe get in contact with this guy... http://www.9bolt.com/gearsets.html
He's in the US, but should come in well cheaper than 600
WA Diffs did my 3.7s for $1650 a couple of years ago. They did a really good job and my diff is just ready for another rebuild now after a lot of punishment.
[YEAH NAH] Red EL XR8 with Trick Flow top end kit, 70mm tb, 73mm maf, 24lb injectors, tweecer, 3.73s & tired T5 = 275rwhp & 13.155@105mph NA. 12.375@116.73 N2O - Off the road, awaiting 347 293ci and Astro Performance gear-kitted T5 (A5)
White EL Series II XR8, manual, high flow cats, single 3" exhaust and Quarterhorse = 236rwhp and 14.18@97.5mph - E7 heads FTW! - SOLD
Scaffy is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2009, 04:57 PM   #18
DW260
DW260's Avatar
I had 3.9 diff gears put in a while ago and it cost me $1680. That included brand new gears, LSD cones, bearings and labour etc etc.
That was in Canberra, but I wouldn't imagine there would be too much fluctuation in prices between the states.
While I'm reasonabley happy with the difference the 3.9's gave me, I could think of better ways to blow 2 grand on a car...
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2009, 09:01 PM   #19
Windsor220
Now Fordless
Windsor220's Avatar
They are used gears and only work out about 200 cheaper. Dont even know what diff they're for.
Old 22-10-2009, 11:25 PM   #20
Scaffy
Rlegaur Mbemer
Are they used? Ok, I thought they were new. Haven't read the site properly. They're for our diffs, the BW78, also known as the GM 9 bolt in the states.
Old 23-10-2009, 12:10 AM   #21
Scaffy
Rlegaur Mbemer
Are they used? Ok, I thought they were new. Haven't read the site properly. They're for our diffs, the BW78, and are also known as the GM 9 bolt in the states.
Old 23-10-2009, 01:05 PM   #22
Stattic
Stattic's Avatar
bought a ute diff from the for sale section for $300 as my car is an open wheeler and i am getting the 3.45s changed to 3.9s, new bearings, oil and the centre needs to be shimmed to fit a sedan. im getting it all done for $1100 including them swapping over the centre and putting the new one in so all in all its a very good quote.
another place wanted to charge me 270 for taking out the old centre and putting in the new and $1050 to send the centre off to a diff place just to have the gears setup.
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
