Old 14-12-2009, 01:16 PM   #1
Fredo
Nice kitty . .
Fredo's Avatar
Red face How best to cut plastic?
So, I need to run the air intake from the 80mm hole left by the removal of the lower resonator to the passenger side fog light panel.
How do these panels come out? Just prise them out or push from the back?
I intend cutting slots in this panel for the fresh air to get in, then paint the lower part of both these panels on the front bumper, black.
What's best to cut the plastic with? Jigsaw, handheld fret saw?
Got plenty of sandpaper and files to clean it up with.
Fredo
Just remember, amateurs built the Ark and professionals built the Titanic!
Late 2005 LS CL, 5spd Manual, 5 Door, Titanium Grey
To Do List:-
:- Using 95 RON Fuel (DONE -easiest upgrade of all) :- XR5 Springs (DONE) :- Lower air box removal (DONE) :- K & N Panel Air Filter (DONE)
:- 2.25" Cat Back (DONE) :- DBA Brake upgrade (DONE)
Fredo is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 02:31 PM   #2
leakey
leakey's Avatar
Dremel tool is good. Close to Christmas too, if you dont already have one!
Look, there's a tonne of easy ways to cut plastic. You can even use a soldering iron
to cut through, all be it slowly, many plastics, then trim with a knife. Small notches is
the way to go, cause you cant put it back on! - well not so easily.
Definately take the panel off though. If you can make a "jig" to hold it, including a
guide for where you intend to cut, you'll have less chance of "colouring outside the
lines". You can make that out of cardboard. Maybe mark it out with a white pencil too.
Just take your time.
Failing that, but the $99.00 fog lamps for your model on Egay at the moment, then put the lamps and other bezel back on Egay!. Already cut for you.
Have fun. Let us see the pics when you're done.
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 08:14 PM   #3
casabonka
You can call me Chris
casabonka's Avatar
Check out 819fly's thread as he done the same. Post sum pics once done. Ordering my intake tonight!
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 09:04 PM   #4
melbzetec
Old enough to know better
melbzetec's Avatar
I've used a fine hacksaw blade successfully. Dremel can be hard to use. You have to keep the speed down. In some applications I've found a razor sharp utility knife to be very effective
Old 15-12-2009, 10:24 AM   #5
Fredo
Nice kitty . .
Fredo's Avatar
Cool, thanks Boyz.
Thought about te Dremel but I'll probably never use it again.
I'll do the picture thing and post them.
Fredo
To Do List:-
Old 15-12-2009, 10:58 AM   #6
GTpilot
FG GT 5.4 w/ additions!
GTpilot's Avatar
You don't necessarlily need to go spend 100 bucks on a dremel. Bunnings sell an Ozito branded rotary tool which is pretty much the same thing, paid about $40 bucks for it in a kit. had one for a few years and it's seem some pretty hard use. comes with a meter long flex extension that will make things easier.Use the thin cutting wheels (be carefule they break v/easy), then use a sharp stanley knife to trim the edges.
Originally Posted by prasac
googoo gaga whoops sorry i thought this was the let's be whiny babies thread
GTpilot is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2009, 11:12 AM   #7
Fredo
Nice kitty . .
Fredo's Avatar
Thumbs up
Ta Mate - sounds the business.
Fredo _2:
To Do List:-
Old 15-12-2009, 11:27 AM   #8
leakey
leakey's Avatar
How long can you wait?
http://cgi.ebay.co.uk/Ford-Focus-MK3...item27adc83c8a
http://cgi.ebay.co.uk/FORD-FOCUS-MK2...item3ca8549c82
http://cgi.ebay.co.uk/Ford-Focus-MK2...item27ad9a36ce
Old 15-12-2009, 01:26 PM   #9
Fredo
Nice kitty . .
Fredo's Avatar
Thanks Leaky this gives me a fall-back plan.
Fredo
To Do List:-
