Hey all just wondering how hard it is to bolt a B series motor into my manual XR6 non VCT? Thanks
Just slidin'
If you search on here FTG done it, a few problems with wiring and getting it to run the DVCT. Search and you will find it.
MD Mondeo - For the family
cool thanks
#4 | |||
Did they? I know they did the Typhoon into a Station wagon but i wasnt aware they had done a BA into an AU - could very well be wrong though. Any build threads on it? |
They installed a BA DOHC engine into an AU.
They ran the engine off the AU ECU (used coil pack etc) I don't think they 'finished' it off, but they deffinately had it running. |
Just slidin'
Im pretty sure they had it running bar the DVCT part, meaning there wasnt a gain to be had over the AU engine.
it was running off the AU ECU, so yes.. DVCT wasnt used, the cams were just in 1 position.
there would have been a gain over the AU motor though, just nor as much as you would if you were running the BA ECU. DOHC heads flow better then the SOHC |
Flairs - Truckers Delight
But nowhere remotely near the effort needed to do such a huge swap
Theres a build thread on ford mods about the ba engine into a au, or on second thoughts should be one on here i read not long ago.
Sure it was a au though, as i remember them putting a ba engine into a Eb Ill find the thread
Just slidin'
http://www.fordforums.com.au/showthr...t=BA+engine+au
Because its so hard from people to use the search function...
well there you go.
Save that for later when its quite - ill have a read. Strange how i missed that thread |
#12 | ||
Just slidin'
It was a fair while ago.
Yeah I found that thread yesterday, I might just get a VCT motor instead.
#14 | ||
Just slidin'
Stick with the HP motor instead. They may look worse on paper, but in the real world, the HP engines are easily the pick of the bunch. The fastest AU (TRIPOWER) had an unopened (No cam, no headwork) HP engine in his. So did FS5 (14.5), Stiddy (usure) etc etc.
#15 | ||
Ok I might have to do some research on all this to decide which way i go
