Hi any of you guys know an easy way to fit the sports bar bolts behind cab ? its a pretty tight fit and my pudgy fingers dont fit. Im holdin off loosening the tub bolts and using a jack but if thats the only way??
Can you grasp them in some pointy-nose pliers?
FPV GS Ute #370/Brembo brakes |
No the angle is too extreme, tried a magnet thingo and bluetac on the finger ...no go
![]() Join Date: May 2008
I once fitted a sports bar to a BF II and it was one of those "why did they design it this way" jobs. Absolute pig of a job. The instructions noted that you should jack the car up between the cab/tub to slightly "flex" the join to allow a little more access to the bolts. I ended up sticky taping the nut to a welding rod/peice of wire to hold nut whilst carefully threading onto the bolt.
Sounds like thats the next move , ill try jacking the ute up and the welding rod trick Cheers
yeah i was a bit alarmed when the instructions said jack in the middle and bend the car!!!!!!!!!!
#7 | |||
Glad to here all worked out. It really is one of those jobs!
#9 | |||
Yeah it is a PITA to put the sports bar on. I bent a spanner to the right shape to fit in there.
