25-07-2010, 08:53 PM | #1 | ||
illiterate with cars
before i replaced the drivers side rear tail bulb, i was having this problem
with the tail lights or headlights on, the drivers side brake light wouldnt come on now ive replaced the bulb tonight(narva) and now the drivers side brake light is stuck on with the parkers or headlights switch on and as a side note, with everything off and just the brake pressed down, it looks like the parker light is showing as the brake light on the drivers side |
25-07-2010, 09:01 PM | #2 | |||
BOSS Pilot
sounds like you put the bulb in around the wrong way?
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
25-07-2010, 09:02 PM | #3 | ||
Try replacing the left side rear tail bulb, sometimes the 2 filaments touch sending power from the parkers to the brake lights.
25-07-2010, 09:32 PM | #4 | ||
ill replace the left side tomorrow, if that doesnt work ill have to look at the bulb holder, i cant put the bulb in the otherway because the bulb holder is broken on both sides where the pins are secured down(i think the bulb could actually be upside but i cant tell because the holder is broken)
anyone know how much it is to replace the actual bulb holder? |
25-07-2010, 10:08 PM | #5 | ||
Sedan, Wagon or Ute? I have a pair of AU Sedan taillight looms you can have for $25 posted to anywhere in AUS.
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
26-07-2010, 12:33 PM | #6 | ||
Flairs - Truckers Delight
yes, its busted, grab a new loom. the old bakerlite holders were foolish, the newer (B-series?) plastic ones don't get brittle over time. much much much much much better.
changing the loom is a piece of cake, just take all globes out, unplug on the boot side, slip the grommet through the hole, and do the reverse with the new one.
26-07-2010, 03:27 PM | #7 | ||
Regulator
As above with the looms.
Also, just checking if you replaced with a two filament brake light globe? I've seen some people put a reverse light globe in the stop light and come up with the same problems you're experiencing. Cheers.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
