Just slidin'
Ok, so my car is intermittnely seemingly firing on 5 cylinders. Can be on idle, load, or WOT.
It all happened after I serviced the car, this is what I done: Oil and oil filter Ported Throttlebody Cleaned the PCV Used a bottle of Stop leak as my engine has more oil coming out of it then my wifes hair Degreased it, and hosed it (very quickly, like I do every oil change, and not the engine, just the front of the block, and back). So what could I possibly have done? I just checked the plugs, they were really grotty, and fouled, cleaned them, inspected the leads which are perfect, and still running crap. If I go to accelerate hard, it will go: Brrrrrmmpopmmmpopmmmmpopopopommm. Also does the same when Im stalling up, like it has Anti lag, lol ![]() What have I done, and what can I do to fix it?
MD Mondeo - For the family
Stroking it...
Well as you said to me previously it started after a degrease I am still convinced its something simple..
Had: 347ci AU Then: ![]() Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
Just slidin'
Yeah simple, but what?
Stroking it...
I vote water in dizzy = rooted dizzy
Or burnt lead?
Flairs - Truckers Delight
water in coilpack
either that or its just rooted leads. I had a pair of leads on my AU1 that looked perfect but one just would fire only intermittently. Just slap in a new set of plugs, failing that new leads failing that new coilpack.
AFF Whore
Water in coilpack +1, happened to a mates corolla one arvo and it took us ages to figure it out!
![]() Join Date: Jan 2005
Coilpack is sealed so impossible to get water in it.
I'd say faulty plugs - replace with new.
I drive way too much...
Replace the plugs and / or leads +1. My pulsar did the exact same thing a couple years ago. Was still barely driving but had no guts to it. Never hurts to have new plugs anyway.
How long have they been on there for?
AUIII Straight LPG Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat |
Formally kotevski22
Wrong motor remove the 5 cylinder out and install a 6 cylinder 4litre that should fix it.Try wd over the coil packs,and if you removed lead check firing order.
Formally kotevski22
Wrong motor remove the 5 cylinder out and install a 6 cylinder 4litre that should fix it.Try wd over the coil packs,and if you removed leads check firing order.
#11 | |||
I know full well you see this little bastard and start thinking 'can't be coilpack' ![]() but then it turns out to be, for no good reason. But my money's on something simpler - probably leads.
2006-2016: Regency Red 2000 AUII Ford Falcon Forte Automatic Sedan Tickford LPG "Millennium Falcon" Last edited by Mr Hardware; 18-08-2010 at 10:43 PM. |
#12 | |||
Or leads! Check for corrosion on the end of the leads.
what JC said, and sometimes old leads fail after being removed, after you drown every thing with wd40 or crc if its still no good if your game, pull one lead off a plug by the boot at a time with insulated multigrips while the engine is running
#14 | ||
beat me to it Mik, i was going to suggest that. don't be worried if you don't have insulated multi grips or similar, you can pull the leads of plugs without them while the car is running without fear of electrocution lol. although if you do get jumped its quite a jolt
"Insert witty signature here" |
#15 | ||
Just slidin'
Ok, leads are perfect, they arent very old, and I didnt take them off, except for yeaterday. Its only intermittent (ie: not theere 100% of the time), goes away after 4000ish RPM.
I didnt spray any water at all on the coilpack side, oil leak is coming from the cam tensioner. Im starting to think its plugs though, even though I cleaned them, it made no difference, but they are in pretty bad shape.
#16 | ||
EF-Weapon
Hey, i had similar symptoms on both my old EF and my au fairlane. In both cases it was the coil packs.
The EF was worst, like if you tried to take off from a roundabout it would feel like it was on the verge of stalling, no power what so ever, but would disappear higher in the rev range. I have a spare coil pack sitting round if need be. Send me a pm if interested.... |
#17 | ||
Just slidin'
Well, I actually developed a problem about a year ago, at the drags. It seems to tie in together, but didnt really think it did.
If I load it up in 4th, (d) at 60km/h and then back off, coast, and nail it, it just splutters until it gets back to 1st or 2nd, almost to the point of dying. It also backfires a little, which can sound very interesting. Thanks for that MattyB, On the weekend, Ill try swapping plugs and leads with our other AU and if that doesnt work, Ill try the coilpacks.
#18 | ||
Just slidin'
Well, the 5 cylinder part is all fixed.
Cost about $27. Was the plugs. Add massive LOL to the end of this sentence.
#19 | ||
Just died fast
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
