Old 24-11-2010, 07:12 PM   #1
Mr12345678x
Default Raising height of AU Falcon
Hey all,
My car isn't lowered but scrapes badly when going into my driveway (series 1.5 AU). This happens with most cars in my driveway. I want to get the car raised a bit front and back so it won't scrape and maybe be a more comfortable ride. What are my options, and who should I go to - preferably cheaper is better?
Thanks
Mr12345678x is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 07:20 PM   #2
SSD-85
I ♥ EDM
SSD-85's Avatar
Get an AU series 1, theyve got more ground clearance than some SUVs . In saying that, adjusting its ride height to that spec should work.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 07:35 PM   #3
Mr12345678x
How would I go about adjusting the height? Is it easy to do myself or should I take it somewhere?
Old 24-11-2010, 07:51 PM   #4
GasoLane
Former BTIKD
GasoLane's Avatar
How many K's has it done? Could be that the original springs have just sagged with age. Find out the original height's (front and rear) and check yours.
Having said that, if most cars scrape on your drive maybe fixing the driveway entry angle might be easier.
Old 24-11-2010, 08:02 PM   #5
Nikked
Oo\===/oO
Nikked's Avatar
Arn't AU's high enough standard?
My car only sits 100mm of the ground, its a bit of work getting into driveways, but i can pretty much get anywhere i want.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 08:27 PM   #6
sprint347dave
how about modifing your driveway
sprint347dave is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 08:31 PM   #7
Brazen
Brazen's Avatar
Pedders do a country pack suspension which raises the ride height, I dont think its that expensive.
Brazen is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 10:25 PM   #8
Mr12345678x
This is the car sitting at the top of the driveway
I think they may have sagged, I will investigate the standard height and compare. The car has done 24xxxxkms
Old 24-11-2010, 10:29 PM   #9
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
take the driveway side on and slow
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 10:33 PM   #10
Mr12345678x
Thanks we tried that but the only way to do it was by driving over the dirt on the gap between our neighbors driveway but it's a double garage and we've got two cars, the angle would be too tight for the second car and the driveway's within legal requirements even though straight on everything gets stuck
Old 24-11-2010, 10:45 PM   #11
Mr12345678x
Mine was a series 1 which was after the April '99 update so it's 1" lower front/rear than the first ones - I think this combined with the possibly sagged? suspension is causing my problem?
I don't even know what to replace or look into lol
Thanks for the replies so far though guys it's a good start
Old 24-11-2010, 11:28 PM   #12
frd906
ummm how do you mean lower, i have a series 1 99 feb build and mine sits really high
old pic but still sits the same even with 18s on
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2010, 11:52 PM   #13
ronwest
All Bran = Regular Member
Then it's not fit for the purpose.
See whoever you need to, to get it remedied (looks like you've just bought a new house?) if no go, talk to a solicitor.
That is ridiculous.
Old 24-11-2010, 11:59 PM   #14
frd906
Also the only update i no during the 99 period was a change to smart shield, thats it
Old 25-11-2010, 08:41 AM   #15
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
That is ridiculous.
+1
Old 25-11-2010, 01:37 PM   #16
sprint347dave
if you hit it fast enough,,you mite be able to park it on the roof of ur house
Old 25-11-2010, 02:45 PM   #17
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
saying one 11 year old AU rides at the same height as another 11 year old AU is preposterous
we had cabs that were supposedly identical spec yet some rode like VIPs and some rode like rock climbers. I couldn't work it out - same springs, same part numbers on the shocks, same kind of car.
Old 25-11-2010, 03:27 PM   #18
block58
block58's Avatar
Responding to criticism relating to the height at which the AU sat (in particular the gap between the tyres and the wheel arches) Ford lowered all non-Tickford AU's from the 'AU Update' on reducing the ride height by a further 1" giving all the more reason to be careful with that large front overhang when entering and exiting driveways.
Source: http://www.trueblueford.com/AU1_intro_AUupdate.html
block58 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2010, 08:38 PM   #19
frd906
hmmm, might go to the wreckers and find my self a set then lol
Rear Suspension: (back to index)
Coil sprung live rear axil standard on sedans.
Mounted via a “four link” suspension system with Watts link, on sedans only.
Optional Multi-link Independent Rear Suspension on sedans.
Optional limited slip differential (NA with IRS option - don't ask me why!).
Optional Tickford handling kit (includes front suspension) for all body styles & suspension options.
Optional heavy duty coils and shock absorbers (for use with towing or a gas conversion).
Standard “Wide Track” rear leave sprung live axil in wagon - smooth riding with exceptional load carrying abilities and sag suppression (something that can’t be said about the Commodore equivalent) - Surprisingly the wagon actually handles better than the standard coil sprung standard sedan equivalent!
All Falcons post 'AU Update' (April 99') were lowered 1” front and rear
Old 25-11-2010, 08:59 PM   #20
edroders
edroders's Avatar
i can't believe no one has suggested this yet but have you thought about a set of 20's? that will raise your ride height plenty lol
"Insert witty signature here"
edroders is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2010, 09:35 PM   #21
Mr12345678x
The idea was for the cheapest, 20"s would do the job but aren't economical at all! lol
Next time I'm up there I'm going to try it with planks, just out of curiosity.]
I discussed it with the builder and got him to try with his car and on a ridiculous angle he did get it in without scraping (basically driving on the nature strip) but it's got the legal amount of drop per metre so there's nothing I can do about it unfortunately :(
Old 25-11-2010, 10:06 PM   #22
TheInterceptor
Cruising...
TheInterceptor's Avatar
Id hazard a guess that you have 15"s on. Heaps of tyres to choose from in 15" form, easier replacing tyres than your suspension. Get some 215/70? somthing with more sidewall, lifts your car up a little.
This would only work if your car is JUST scraping. Just an idea....
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2010, 10:35 PM   #23
frd906
so im asumming every one with the same car hieght as your car would have problems getting in, last thing you wanna do is fork out a bill for under carrage damage
Old 25-11-2010, 10:45 PM   #24
Barryxr6turbo
Have you tried reversing in? My ute scraps my driveway going forwards but not backwards.
Barryxr6turbo is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2010, 04:53 PM   #25
Mr Hardware
just looked at that pic
do what ronwest says, that's a joke
Old 26-11-2010, 05:51 PM   #26
GasoLane
Former BTIKD
GasoLane's Avatar
Looking at the pic (and I agree with others, It's a ridiculous angle) I'd say it's not scraping as we all were thinking. It looks like it would be bottoming out in the middle.
Good thing you don't own on old Fairlane, you'd get all four wheel in the air!
Old 26-11-2010, 06:16 PM   #27
Barryxr6turbo
Yeah that's what I was thinking. My driveway is similar but I miss the muffler in 1 direction but not the other.
Old 26-11-2010, 08:08 PM   #28
Jimmyd
New set of std springs would set you back around $300-$500, pay someone to fit figure on another $200-$400; so basically $300 to $900.
This sort of money you should be able to get a concrete grinder in to take to peak off the driveway.
Grinding down the peak will also fix access for other cars, increasing ride height will reduce your cars handling ability.
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
