Hey Guys, car was idling a bit high for my liking, about 800-850rpm, accelerator was very sensitive off idle and I read in one of the posts that setting the idle correctly can help with this issue.
So ran through the procedure, disconnecting battery to reset ECU, disconnect ISC, start engine, set idle to 600rpm, turn off engine, plug ISC back in, restart car, idle comes up to about 650rpm, perfect. Onto the next step, check voltage on TPS, which apparently should be under 1.0V, mine is at 1.03, so not too far off, but I thought may as well do it to recommended specs, loosen screws on TPS only to find that it is non-adjustable. So just wandering, has anyone else found that the holes are not elongated for adjustment? Also I read a post saying that up to 1.2V is within range for idle, so whats the deal, is it 1.0V or 1.2V? Was the adjustable TPS 1.0V limit for EA-EF and doesnt pertain to AU? Any ideas or help?
Bronze Wine XY GS Fairmont Resto |
Hmmm, interesting read:
http://www.eectuning.org/forums/viewtopic.php?f=2&t=502
Flairs - Truckers Delight
#4 | |||
It's a joke from the movie 'Office Space'. It has nothing to do with falcons except for the acronym TPS - but here's the full size one anyway
http://upload.wikimedia.org/wikipedi...Tps_report.png
Ha Ha, actually I think its quite appropriate after spending hours trying to find info only to be back at square one.
You can elongate the holes yourself. Drill them out slightly and carefully.
#8 | |||
The Ford AU eec has automatic TPS calibration.
Basically it measures the lowest read TPS reading, and calls it TP ratch, and uses this as your idle TPS voltage. Playing around with the TPS will change results, especially if you increase the TPS voltage, but reset the eec, and it'll all be the same again TPS voltage of 1volt is for US car's, not australian. As a rule of thumb the TPS should be within 1.2volts max and 0.7volts minimum.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
#10 | |||
Just a couple of quick q's, If it's for US car's only why do so many people here in Aus talk about adjusting their TPS'. I also noticed in that link I posted that it mentions early EECV's didn't have this automatic adjustment, which had me wondering with my car being a series 1 if it may have one of these "early" type. Thanks again for your help. Much appreciated.
#11 | |||
Replaced it with another TPS which is on the car at the moment, which reads about 1.15v at idle and it does not run any better/worse than what the one with elongated holes did when it was under 1v and working properly. The explanation that 5.0 ED has stated makes perfect sense and I wouldn't bother mucking around with it. Was a complete waste of time for me with no results. I think the E-Series ECU's are different and this is why the E-Series guys keep an eye on the TPS voltage.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
#12 | |||
RIP...
. Oval Everywhere... |
Yeah you cant relate everything US about EEC's to aussie EEC's, even E series and EEC IV the TPS setting is set with a ratch setting and therefore no adjustment required.
However i will point out that E series with the seperate transmission computer, then the transmission computer does require a more limited voltage adjustment at idle, at which case its 0.8volts not 1v.
