Old 28-06-2012, 04:14 PM   #1
T2TICK4D
T2TICK4D's Avatar
Default problem
hi guys and girls i have a 1999 au1 xr8 done 200,000kms and here are the problems
the motor has a bad vibration at about 1100RPM
the auto sometimes changes gears ruff
and the LSD has a really annoying wine
i was wondering whats the best oil to use in the gearbox and diff, and
why is the motor vibrating so bad its really annoying
TE50 T2
AU2 GHIA
T2TICK4D is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2012, 04:23 PM   #2
I reckon
I reckon's Avatar
Default Re: problem
probably needs new plugs and leads .
if you look at the motor on idle has it got the wobbly boot on?
I reckon is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2012, 05:15 PM   #3
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
Default Re: problem
Does the engine vibration decrease with engine revs? If so, replace the harmonic balancer....They have a habit of crudding themselves and causing the vibration you describe
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 28-06-2012, 08:07 PM   #4
T2TICK4D
T2TICK4D's Avatar
Default Re: problem
no the vibration calms down when you rev it i replaced the leads still there i just pulled a spark plug out and they are really bad i think they may be the problem
TE50 T2
AU2 GHIA
Old 28-06-2012, 08:12 PM   #5
b2tf
not here much anymore
b2tf's Avatar
Default Re: problem
start by doing plugs and leads, also clean MAF and throttle body, if that doesnt fix it then harmonic balancer would be the next bet.
Transmax Z is what I use in the gearbox (but mine is manual) and SAF-XA for the diff.
2024 F150 XLT
Old 28-06-2012, 08:39 PM   #6
fordman302
fordman302's Avatar
Default Re: problem
I destroyed a harmonic balancer on my old nf v8, the mechanic told me originally the vibration was caused by dirty injectors when all along it was just the balancer detatching itself, it also calmed down at about 1500 revs and upwards
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2012, 08:43 PM   #7
macman
macman's Avatar
Default Re: problem
Vibration is the balancer or engine mounts.
Transmission needs Castrol TQ95.
macman is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2012, 09:38 PM   #8
FGII-XR6
FGII-XR6's Avatar
Default Re: problem
at 200K it probably has the original coil pack and it is way past it's use by date. a dodgy coild pack can cause the problem you describe
[SIGPIC][/SIGPIC]
Rides:
Old 29-06-2012, 12:49 PM   #9
T2TICK4D
T2TICK4D's Avatar
Default Re: problem
thanks everyone i got some new plugs today ill see if this works
TE50 T2
AU2 GHIA
Old 29-06-2012, 03:04 PM   #10
sd1800
Default Re: problem
Most falcon diffs practically whine from factory. I wouldn't worry about it too much. Change the diff fluid.
Likewise with the auto, do a full fluid flush (not just a drop pan). If this doesn't fix it you might have a dud solenoid. While your doing the flush, it's a good idea to install a external transmission cooler from ebay and have it bypass the radiator. Not too expensive.
Vibration definetely sounds like harmonic balancer at those RPM. They tend to cause most troubles between 1000-1500rpm.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2012, 04:40 PM   #11
svo supporter
Default Re: problem
Originally Posted by macman
Vibration is the balancer .
Here's the answer.....I had the same problem with my NF Fairlane as the OP has described...Replaced the balancer and no more vibration.
Old 29-06-2012, 09:00 PM   #12
T2TICK4D
T2TICK4D's Avatar
Default Re: problem
Ok I got new plugs and no luck looks like its the balancer
TE50 T2
AU2 GHIA
Old 01-07-2012, 12:36 AM   #13
T2TICK4D
T2TICK4D's Avatar
Default Re: problem
i also replaced the radio buttons on the steering wheel today and now my after market jvc stereo won't work dose anyone know what it could be ?
TE50 T2
AU2 GHIA
Old 01-07-2012, 08:09 AM   #14
GK
Walking with God
GK's Avatar
Default Re: problem
If you put S2-3 Buttons on a S1 (or vise versa), this is probably it. It's a compatability issue between them. I see you have a S1. Look at the buttons now on it. Does the top left button have an "s" in a circle? If so, you've put S2-3 buttons on your S1. To confirm this, check the old buttons. No "s" on those, means you've crossed series'.
BTW, if you have your aftermarket stereo working with your steering wheel buttons previously, someone has done some good compatability work. It's a little fiddly and depending on how you go about it, costly too. By costly I mean between $100-200 odd, but many here wouldn't pay that. I'm in that group! LOL!
I must say though, the wheel mounted controls are certainly handy.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 01-07-2012, 02:00 PM   #15
T2TICK4D
T2TICK4D's Avatar
Default Re: problem
the buttons i put in are off my series 2 au fairlane i wrecked so id say thats what it is then thanks
TE50 T2
AU2 GHIA
Old 17-10-2012, 08:42 PM   #16
jusTANG
jusTANG's Avatar
Default Re: problem
how did you end up going with this?
jusTANG is offline   Reply With Quote Multi-Quote with this Post
