Got a price back from superchips its $344 delivered however they say it doesnt read some of the aussie ecu's so im thinking the thai built models. But seems as though 1 of these bluefins can be used on more than 1 car?
Anyone bought a bluefin for their fiesta ws or wt only?
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
Also keen to find this out!
Chip tuning only works if you have existing supporting engine mods right?
Extra Power = paying for it in Efficiency, Emissions & Reliability? I mean, wouldn't Ford have tuned their chips for this stuff already? |
True but the focus has same engine as fiesta with more power and torque and the fiesta metal has more power again better economy. Only diff being higher rev limit and louder rear muffler.
Though as I understand the Focus and Fiesta Metal both have different intake and exhaust systems than the base Fiesta.
That should let them give it a different tune without sacrificing too much economy while keeping the reliability. |
I have inspected the metal against my cl and all part numbers on intake inc maf as the same and the exhaust is identical even diametre only the rear muffler exits changed.
Hmmm, the Metal is rated at 0.1L/100km less fuel use than a regular WT too.
All the engine innards are identical as well? If so, maybe pay for it on an earlier engine rebuild? Or maybe stock Fiesta engines are de-tuned for marketing reasons? |
the engine number prefix is different as ones from germany ones from thailand
the intake manifold and all piping has the same numbers though. i would say the metal might have something else done but i seem to think the reason for the higher output in the focus is due to the fact people would not buy a focus with a fiesta motor if that makes sense..although it is
having Fiesta withdrawals
The Bluefin will not work on a WT. Different ECU set up, I don't really understand the differences but apparently that is the case.
The Metal has the dual intake and I think a different exhaust (it is a WS anyway) According to Pumaspeed the Pipercross intake gives another 6hp and the full Milltek around 15hp from memory...maybe that is your best option although obviously it requires more coin.
New: Ford Focus RS in Ultimate Green number 82/315 Past: 2009 Ford Fiesta LX in Vision Blue - Sold |
#12 | ||
Superchips are coming out to aus next month and will take a s an back of the wt ecu. Hopefully they can make it work on our WT's
$1700 approx landed for the pipercross 141ps kit that intake and full exhaust.
I can't see any reason the metal tune wouldn't flash into the standard ws, real pity my friend no longer works at a ford dealer or I'd have given it a try
#14 | ||
Bluefin worked wonders on my modded WS. 2.0 update also brought a rise in the rev limiter to 7000rpm. Engine is still pulling hard when limiter abruptly kicks in bang on 7k. I have a full Milltek system, j1 cai, iridium plugs and other bits and pieces but the best low-buck power gain is ANY cold air induction as the Fiesta is really strangled. It was a real seat-of-the-pants performance improvement. J1 cai are top-shelf but same performance gains can be made on the cheap. Despite a daily flogging gas mileage rarely goes over 7L per 100k.
Fiesta WS, Milltek tubular exhaust manifold' 200 cell cat, full milltek stainless race system, j1 CAI, Bluefin remap, ford race shifter, Team Dynamics Race rims 17x7', Spax Coil Overs, iridium plugs, CFM 8.5mm leads, R1 drilled & grooved discs & ceramic pads, HEL braided s/s brake lines, econetic front under tray & fitting kit, CG Belt lock, Bridgestone RE002, Armster arm rest, Rack limiter, PowerFlex Bushes. FOR SALE!! |
#15 | ||
@geelong festy, ive been meaning to ask, which bluefin did you buy, because im looking at ebay and there are two options for the MK7 which are the WS fiesta's.
there is this : http://www.ebay.com.au/itm/Superchip...437e227&_uhb=1 OR http://www.ebay.com.au/itm/Superchip...d780d84&_uhb=1 thanks for helping out man, and your fiesta sounds like an awesome weapon. |
