hey guys my au 6 cylinder is using a large amount of engine oil (roughly 1 liter a week) trouble is it doesnt leak oil anywhere or blow smoke as far as i know what could this indicate?
#2 | |||
Au Falcon = Mr Reliable
cheers, Maka
oh thats interesting cause the pressure sender itself is actually playing up on me the guage moves all over the place whilst driving so ill look into that thanks
#4 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Checked the Header tank
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Auto Nerd
When I had an after market metal PCV valve in, it was sucking all the oil out of my engine. Wasn't 1 litre a week, but I guess it depends on how much driving you do. It was about half a litre every 1000kms.
header tank is fine and i changed the metal pcv valve for a plastic one in hope it would solve the probem, one question though should there be oil in the pcv valve itself? because with mine you can see a drops of oil on the inside
Auto Nerd
You do get a bit of oil in there, can't really avoid it. Maybe try putting a clear piece of hose on it from an aquarium or Bunnings and have a look at just how much is getting through. Just dont forget and leave it on, as they tend to melt and block the IAC valve operation. Dont ask me how I know that.
What do the plugs look like? |
#8 | |||
cheers, Maka
only on a series one, on the series 2/2 the gauge is a fake and just uses a switch. the fake gauge always reads the same pressure unless the switch is open when it reads zero
[SIGPIC][/SIGPIC]
just searched all over the engine block low and high side to side and there are no traces of oil so it must be getting used while driving :/
#11 | ||||
![]() Quote:
Big dreams, not enough money ![]() Smoke tyres, not drugs ![]() ![]() |
#12 | ||
Jt, if you believe its burning oil, maybe check you're spark plugs to see any signs of oil fouling like Evgeni suggested? Had a look at the rear main seal yet?
cheers, Maka
Unfortunately no, I looked into it for my XR6 some years ago
[SIGPIC][/SIGPIC]
#14 | ||
Call me dirt... Joe Dirt
Take it for a blast around a race track, that usually helps. Sometimes driving it too conservatively gets them sooted up.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
#15 | ||
For some things that's a good idea but for high oil consumption that's defiantly not the way to go, could end up doing damage
[SIGPIC][/SIGPIC]
#16 | ||
Oops, ok... maybe not good advice without fully understanding the problem.
#17 | ||
LIFELONG DJR SUPPORTER
I don't know, it might help the issue develop to the point it is easier to find, or it might provide the cure you hope for. All good, or blown up motor. Either way, will be fixed! lol
#18 | ||
thanks for all the good advice so far guys i will check the spark plugs on the weekend for traces of oil but i still am uncertain of this, if the car is using so.much oil.and consuming it through combustion would there be any traces of visible smoke? or could it burn it without the smoke?
#19 | ||
You would think there would be smoke visible, i would have a look anyway just to cross it off the list of possible causes.
cheers, Maka
