Old 08-09-2013, 10:27 PM   #1
meanfalcon
Default Au XR8 220 not starting
Just pulled the xr8 out of the shed after a couple of years stuck in a new battery and no go. Checked and cleaned half the plugs ok split the fuel line in the engine bay and no fuel. 20 litres 98 Ron and still nothing. So pump or filter or ? What
meanfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2013, 10:35 PM   #2
meanfalcon
Default Re: Au XR8 220 not starting
Can't find the pump. The filter is under the rear should I undo the fuel line here to test flow.
Old 08-09-2013, 10:54 PM   #3
Nic302ef
Cocoloko
Nic302ef's Avatar
Im guessing cranks but no fire...
check basics, like spark at a few leads,
If its been sitting for a few years with the pump emersed in old fuel, it can damage the pump quite quick when you first go to use it again.
Pump in in the tank, its mounted on the sender unit, access is through a plate under the boot carpet
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build.
2010 Territory: family bus.
79 P7 LTD 351.
Nic302ef is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2013, 11:05 PM   #4
needaXYGT
AU II XR8
needaXYGT's Avatar
If your getting the letter "t" come up on the instrument cluster, then turn the key to ACC, leaving it 30 seconds to a minute, then turn the key off. Once you've done that try starting it again and see how is goes.
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2013, 08:51 AM   #5
meanfalcon
I have seen the letter T in the display and didn't realise that would prevent it starting. One concern I had was the computer losing memory as it was flash tuned about seven years ago but I have got a spark and cleaned the plugs on the right hand bank.
Old 09-09-2013, 11:53 AM   #6
meanfalcon
Tried again this morning. The letter T has gone but no go. I'll try an ECU reset.
Old 09-09-2013, 01:41 PM   #7
needaXYGT
AU II XR8
needaXYGT's Avatar
Does the starter motor at least crank the engine over?
A little more info and we can narrow it down a little more
AU XR8 II ute
Old 09-09-2013, 06:04 PM   #8
meanfalcon
Yeh with the new battery it's cranking over fine. Just did a ECU reset turned on the ignition the T came up turned back to accessory for 30 sec and tried again but no luck.
Old 09-09-2013, 09:20 PM   #9
Gaz
Got Ghia?
Gaz's Avatar
Can you hear the fuel pump priming? You can usually hear it from the drivers seat, otherwise stick ya head in the boot and have someone turn the key on without starting it. should hear the pump run.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2013, 08:17 AM   #10
meanfalcon
Can't hear anything. I wonder if I take out the pump if I could free it up. But I guess I'll have to cut the silicone seal in the boot to get to it.
Old 11-09-2013, 09:09 PM   #11
Gaz
Got Ghia?
Gaz's Avatar
if you got a test light check that your gettin power at the pump.
They can die for no reason. My EF died while I was sitting at the lights.
