Hey all!
i did a search but i couldnt find what i wanted :( My au xr has problems starting sometimes. It trembles and i need to give it some pedal to start! Anyone have similar problems!!?? |
RDP #181
every once in a while i used to have this prob in my xr8, i mentioned it to the service centre and the clened my throttle body and injectors, this has helped hugely although it did do it again the other day.
okies cool! whats the best way to clean out the throttle??
get some throttle body cleaner and take off the air intake pipe, spray it down the throat of the throttle body and wipe with a rag
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
Audi S3
my car as of late has been having trouble kicking over... the otherday it was cause i had eff all petrol but i filled up today and it did the same so i dunno.
Fantastic Plastic
Now and then i have had it happen when switching between different power modes with the adaptive shift auto. Also i had it happen a few times when i was a bit broke and was just using normal unleaded (could be the fuel ?), nowerdays i just run it on premium unleaded and i don't have a problem , unless sometimes still as mentioned above when changing power modes (when 1'st started in the new mode only) .
Barra Turbo > V8
i have the same problem AU's are prone to fuel pumps so id say it is probbably that i thought it was the altinater not charging the battery but had it tested im sure its my fuel pump
-2011 XR6 Turbo Ute -2022 Hyundai Tucson Highlander Diesel N Line |
_Oo===oO_
You shouldn't need to use the accelerator to start the car - although I guess you already knew that lol.
Ok, so it's got no problems turning over, just firing yeah? If that's the case what I would look at first would be T/B first, then injectors then work your way from there, filter, pump etc.
i think mine has the same problem
on occasion (on any sort of ground level.. sloping doesnt matter) ill hit the key and it will kick over then splutter and stall then ill cranker her over and it wont fire at all.. then i turn it all the way off.. then click slowly thru the ignition(so it gives time for tha fuel pump 2 make sure its all pressurised etc) and ill do it and it will usually start then.. but other occasions it takes ANOTHER kick to start and i have to catch it with some throttle.. very strange i think ill give the t/b clean a go
#11 | |||
1. Idle Speed Control valve not working 2. Battery on its way out. My olds' car was doing this - starting, idling, then dying. Turned out to be the battery. So clean the ISC out first, and if that doesn't improve it, get the battery tested - it may still show 12 volts, but it may not have much currect capcity so will drain very easily and quickly.
#12 | ||
SS Grunt
hey i had this prob in my g/f's ef futura i6, would start then stop and shake, and sometimes it would almost start and just shake around like it wasn't firing, got the batt tested it turns out a few plates had collapsed, changed batt, 600cca later it starts like its on speed and hasn't missed a beat, yet. hope it helps
NOTTY
mine still does it
it gets vapour lock |
#14 | ||
Barra Turbo > V8
JC how do u clean the ISC my prob is almost identical but my car has a new battery
#15 | |||
Smile
