Old 15-11-2005, 12:25 AM   #1
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Default Maintaining your new car warranty
Judging by feedback to RACV, the topic of new car warranty coverage can be a source of confusion for members. This can also lead to frustrating, time and cost-consuming disputes with dealers and manufacturers.
If you are about to, or have recently purchased a new car, understanding what is required to maintain your factory warranty is particularly important. It may also help you avoid some of the aforementioned disputes altogether.
In simple terms, the owner is required to ensure the vehicle is serviced within the specified maximum time and distance intervals schedule as outlined in the owner’s handbook. In practice this should be done by a qualified mechanic, typically (but not necessarily) at an authorised dealership.
It also means operating the vehicle in a reasonable manner, within the bounds for which it was designed. Entering the vehicle in a motor racing event is an (extreme) example of usage likely to be judged as ‘mechanical abuse’. In such cases, subsequent damage would not be covered by the warranty. Acceptable use will also vary for different types of vehicles, e.g. between a small passenger car and a large 4WD designed for serious off-road use.
The manufacturer’s warranty will not cover the performance and reliability of aftermarket parts (i.e. those of a different brand to what was originally fitted to the vehicle by the manufacturer). Nor will it cover subsequent damage caused by their failure, such as engine failure resulting from a defective aftermarket oil filter.
An occasional misconception is that a manufacturer may cancel or void a new car warranty altogether, if these requirements are not fully adhered to. While warranty coverage may be denied for individual parts or even a component assembly proven to have failed as a result of owner negligence, this does not directly affect the coverage for other, separate components.
An example is when an owner neglects to have his vehicle serviced within the stated limits of time and distance travelled, which in turn eventually leads to catastrophic engine failure. In this case the dealer may legitimately refuse warranty coverage for repair costs to the engine.
However this would not necessarily affect continued warranty coverage for other components not reliant on preventative maintenance, for example airbags or the instrument panel.
Of course it makes far more sense for the owner to avoid such scenarios altogether, by ensuring the vehicle is maintained in accordance with the requirements outlined in the owner’s handbook.
Story courtesy of RACV
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 12:48 AM   #2
johnydep
johnydep's Avatar
Good read.
A lot of people think the manufacturer’s warranty will cover them no matter what, some also think that they need to take it to the place of purchase to honour the warranty (which they don't).
johnydep is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 08:47 AM   #3
ltd
Force Fed Fords
ltd's Avatar
Good Read,
I read elsewhere that there has been a bit of a crackdown on vexatious warranty claims i.e.; people abusing their cars to the point of requiring several differentials throughout the warranty period. Apparently Ford has refused to honour a warranty claim on a 3rd diff for a guys GT that has been photographed doing burnouts all over Sydney.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 11:46 AM   #4
Bossxr8
Peter Car
Bossxr8's Avatar
Some dealers can be stupid though. I heard over on the turbo forums that a guy was denied warranty on his Premium sound screen as he had an APS Ph 3 on his car. WTF.
Old 15-11-2005, 12:02 PM   #5
Bearman
Moderator Ford Coupe Club
Bearman's Avatar
And so they should!! Good on them.
Mitsubishi ASX Auto, White - Daily Commuter
XC Fairmont Coupe, 351 4spd, Graphite Grey - The Antidote
http://www.fordcoupeclub.org
"If you don't know where you're going, any road will take you there" George Harrison 2001.
Bearman is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 12:08 PM   #6
HSE2
7,753
HSE2's Avatar
That does make one think.
BREAKING NEWS: The Pity Train has just derailed at the intersection of "Suck It Up & Move On" after it crashed into "We All Have Problems" before coming to a complete stop at "Get the Hell Over It." Reporting LIVE from Quitchur Bitchin'
HSE2 is offline   Reply With Quote Multi-Quote with this Post
