hi all
had some trouble geting the car started recently its bin siting in the shed for about a month now(respray) and i tryed getting it going and i wont start the starters doing its job the fuel pump is muming at the start of but wen i pulled the spark plug out thay r dead dry i'v hade some electricle prob's resentlly too would screwing around withe the smart lock moduel(pulling it out and swaping it over) affect the injecter's some how because it's getting fuel to the rail but seams it's not getting thru the injectors n e help is greatly appretiated cheers pat. |
check the fuses one of the top row ones can make the car not fire when the fuel pump and stater is working.
have you pulled th fuel line off the rail ? check for fuel, or loosen the clamps and crank it, should get fuel squirtin out.
all the fuse's are good chead all of them today
yer damo fuels coming out the line in to the rail unscrew'd the hose clamp a bit and it started scwerting fuel out |
listen for a ticking sound from the injectors when you crank it.
yer mate il give that a shot tomoro plus
would the BEM unit have n e thing to do with the engine wiring loom?? or is it purely for intirior electrics eg. lighst's,climate controle,dash displays,all that cheers pat. |
it will just be the ign coil it will have a small crack in it and when it was sitting it would have got some dust and moisture in it and it will be shorting out. put a new one on it and it should fix it i keep a coil handy when i do break downs as it is normanly just that, if you don't want to buy a new one borrow one to try from a mate.
[EBGLT]
Are we cranking now?
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
nope not yet man
havent had n e tme to get around to trying some ideas out(painting all day:P) but next week wen i have some time ill have a nother look and get stuck in to her cheers guy's for ur help ![]() p.s this isnt JJM it's EDXR6T wrong account ![]() |
