SS Grunt
hey just a quick one, has anyone had any issues with their hi stalls of change over converters vibrating, my engine is fully balanced and with old converter it never vibrated, no with the new one which is meant to be balanced it seems to vib at about 4000 through to 6500. can turning the converter 180degress help this problem or is it just out of balance all together.
Are you sure its the converter?
SS Grunt
Has to be its the only thing i have changed and it neva did it before with old conv. tailshaft is in orig spot, its doesn't vibe at 100k or anything just once you rev it up past 4, the only other thing i noticed is that i could reach 95km/h in 1gear at 6400 and now i can only reach about 80-85 at 6400 but vibes are only light but any vibe is bad .
Smile
Make sure the flywheel bolts are in properly. If they are then your converter has not been made properly.They are supposed to balance them when the reweld them back together.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
SS Grunt
definanty in properly cause i put locktite and marked the first one and went around twice. never came loose when i put new engine in still tight as when i put them in. so its got me stuffed. do you think it would help to undo the bolts and then rotate the convertor 180deg to see if it helps.
Smile
I feel for you mate and it really ticks me off when things like this happen.I think you need another stallie which is balanced
SS Grunt
Yeah i know see first i thought it was just me and my car but now i read all the things on here and most people some prob or another. i rang up the dude and he was pretty cool about it and suggested to try aND rotate it too all possy's and tonight after trying all pos it is still the same, goes good but still vibs a bit, maybe have too pull her out and send it back and see what happens.
