Old 02-07-2006, 10:18 PM   #1
AUIIXR8_Tas
Default Painting XR8 rocker covers - stupid question
Right then.
Let's say I got hold of a set of rocker covers for my Windsor and wanted to get tham painted up. What is the best wat to go about it and what is involved in removing the old ones/replacing them, as far as gaskets, etc goes? This is a new hobby for me, I'm not too familiar with this sort of stuff, to say the least.
Cheers.
AUIIXR8_Tas is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2006, 11:05 PM   #2
JC
JC's Avatar
I've got a set already painted in Black wrinkle/crinkle finish. Yours for $100 including postage.
Not too hard to swap them over - just a matter of undoing the 1/2 dozen or so bolts, and I just used the same gasket. Can't remember whether I need to remove the intake manifold, but I'm guessing I did.
Ford Performance Club ACT
Old 08-07-2006, 09:47 PM   #3
Soundwarp
Blue to the bone!
Soundwarp's Avatar
I'd like to see some pics of this if you get into it
BA GT-P in the garage
http://img.photobucket.com/albums/v7...dwarp/fbar.jpg
Soundwarp is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 11:58 PM   #4
Free347
You'll have to remove your upper intake manifold to remove the rocker covers. It's pretty obvious what you'll need to do as you go along. If you are using cork gaskets then you'l need to clean the gasket residue of both the rocker covers and the head surface (be careful to keep gasket bits out of the heads) before fitting new ones. If you're using the metal and rubber resuable ones then no problems.
Painting is easy enough. Make sure they are well cleaned of grease etc, give them a light sand with wet/dry paper, another good wash and then paint the colour of your choice. It is possible to use most paints as the covers don't get that hot however engine paint is recommended as it will cure to a tougher finish.
Better if you can pick up a spare set to prepare beforehand and then just change them over in one go rather than have your car off the road while doing your covers up. It just so happens there's a cheap set on eBay at the moment, hehe - click here.
Free347 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2006, 12:30 AM   #5
AUIIXR8_Tas
Hah! That would be the same auction that I've been watching for the last few days.. Infact these rocker covers inspired me to consider the whole painting thing to start with!
