Old 22-03-2005, 03:29 PM   #1
MintEAFalcon
1990 EA Falcon S Driver
Default EA Series II Tibbe lock conversion...
Hi guys,
Just got a quote out of City Ford in Melbourne for Tibbe Locks. $128.70 for the front doors + ignition + 2 keys and $72.50 for the boot lock + 2 keys.
What I am curious about and maybe someone can shed some light on the subject is why they aren't sold in a complete kit, ie. Doors, ignition AND boot all keyed alike.
Is there anyway of getting around having to have the two sets of keys?
As far as the installation is concerned, I am planning to source a steering column from a post EAII vehicle to get the two sheer bolted stronger barrel.
My second question is how does one remove the existing tibbe lock from the barrel, with no key, if the lock needs to be turned to the ACC position?
Are there any other potential problems I might run into with such a conversion?
Thanks in Advance!
Mark.
MintEAFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2005, 03:32 PM   #2
Sundeep
Sundeep's Avatar
I got the whole set of lucks for $90 just 2 years ago.
Sounds a bit weird.
Try Grant Walker Parts in Bayswater. I don't have their number but you could call up operator assistance or whatever and get their number. That's where I got my locks from.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2005, 03:33 PM   #3
InitialD
Low and Loud
InitialD's Avatar
My locks came curtesy of Jolly Rodgers, Steering column change was quite easy
Old 22-03-2005, 03:35 PM   #4
dansedgli
dansedgli's Avatar
I have all the door locks for $20, no keys though.
Does that help?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2005, 03:42 PM   #5
MintEAFalcon
Thanks InitialD. What I am curious about though is how you go about removing the existing tibbe lock from the replacement steering column to fit the new one that came with the kit, if you dont have a key for the old one. If that makes sense.
Old 22-03-2005, 03:44 PM   #6
MintEAFalcon
Originally Posted by Sundeep
Try Grant Walker Parts in Bayswater. Sundeep
You guys are quick Thanks Sundeep. I actually bought some clear indicators from them so I will give them a try too. Cheers!
Old 22-03-2005, 03:46 PM   #7
EA2BA
PM me if you want
EA2BA's Avatar
I just swapped the whole steering column over when I did mine, seemed a far easier option then removing them.
Old 22-03-2005, 03:54 PM   #8
MintEAFalcon
Hi Dellboy999. Did the new steering column have an existing lock in it though? I am planning to source the column from Pick-A-Part and they all seem to have locks in the barrels. I assume it would need to be replaced with one that is keyed the same as the door locks I purchase?
Old 22-03-2005, 03:57 PM   #9
EA2BA
PM me if you want
EA2BA's Avatar
yeah i got the steering column and full set of locks, including boot, all keyed the same and swapped it all over, if you upgrade to EL door handles you dont need a passenger lock
Old 22-03-2005, 04:35 PM   #10
Sundeep
Sundeep's Avatar
You can't get the barrel out of the lock assembly without the original key. I don't think there is any way around it. You'll just have to find a lock assembly with the barrel already removed.
To get the barrel out you need to get the key, put it in to the IGN position and then press a pin, which is on the barrel, through a hole in the igntion lock assembly. I hope that makes sense.
Sundeep
Old 23-03-2005, 02:46 AM   #11
d_slayer
d_slayer's Avatar
i got a locksmith to drill it out.. cost me like $65 tho ..
95 EF Futura. Ported, slotted, lowered,mags,2.5" Exhurst inc CAT, extractors,Manual,brass button clutch,Limo Tint,Trip Comp, Full Blue Dash, Dual Battery and one kick A$$ Sound system.
d_slayer is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 10:25 AM   #12
MintEAFalcon
Sundeep
Thanks Sundeep...Thats what I suspected!
Old 23-03-2005, 10:25 AM   #13
MintEAFalcon
Thanks D_Slayer... Thats an option, an expensive one though!
Old 23-03-2005, 02:11 PM   #14
MintEAFalcon
OK. Tried Grant Walker Parts on the advice of Sundeep.
Now the guy I spoke to there said the early tibbe Falcons came with seperate keys for the boot and doors/ignition. Can anyone confirm this?
He also mentioned the steering column needs to be rewired to suit the non-tibbe vehicle. To those who replaced their steering column, did you find this to be the case??
Are the door/boot locks a straight swap with no mods required?
Old 23-03-2005, 02:18 PM   #15
d_slayer
d_slayer's Avatar
i got mine from a eb wagon (mine was ea sadan) all locks just changed over .. i did need a ignision as mine was the old flat type key.. which the one i got was a smartlock one (eb) and i just left the wire disconnected ( nowhere to conect them to)
