Old 23-08-2006, 04:22 PM   #1
xalent
Red Eye Racing
xalent's Avatar
Default Front Swaybar Removal
Guys,
I'm curious if removing the front swaybar will help my car to launch a bit harder. Has anyone noticed any difference in 60ft times with and without swaybar installed?
xalent is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 06:10 PM   #2
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
Originally Posted by xalent
Guys,
I have removed my front swaybar on my BA and noticed a little better weight transfer, seem to run alot more consistant without it well the two times I did it I was the most consistant I've ever been and did my best 60ft.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 09:00 PM   #3
northey
Guys,
What difference are you hoping it will make? Is it the XA in your avatar? Is it on slicks? What times do you run?
If it is that car the difference probably will not be noticeable. The xa isn't a lightweight as far as racecars go and removing a 3kg bar from the front won't make a big difference.
But try it anyway; it's the only way you find out. If you can get consistent 60 foot times with it fitted then remove it and it runs a different 60 ft time you learnt something. If it drops even .05 seconds off your 60ft you're laughing.
northey is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 09:35 PM   #4
MYWPN
MYWPN's Avatar
Could you notice that the front of the car raises higher on take off??
im very interested to know because im looking for a bit better weight transfer without spending money. how much did you shave off your 60ft and what were they?
11.1@127.41mph 360rwkw (unopened)
built bottom end with H-beam rods
400+ rwkw c9 and nos. much much much more to come soon
MYWPN is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 11:14 PM   #5
xdclevo
The Fun Mobile
xdclevo's Avatar
I remeoved mine and fitted a new convertor and went from 1.95 to 1.70. Probably mainly the convertor hepled this, but apparently loosens up the front end to help in transferring weight to the rear. I didn't notice anything in the handling on the street, so the sway bar is gone for good
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 11:22 PM   #6
MYLO_XR6
MYLO_XR6's Avatar
would you recommend removing the front swaybar on a stock drivetrain BA with 163RWKW? Auto.
Goin Caulder Friday if it doesnt rain.....i know its a good idea, but is it recommended for the "lower" horsepower cars?
MYLO_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 11:49 PM   #7
xr8ute
Back on the road
xr8ute's Avatar
I removed my front swaybar last time I was at the track....I am not really traction limited off the line so I didn't notice any real difference.
I tell you what though, (on the AUI at least), it weighs a lot more than 3Kg.
Like xdclevo, I didn't notice any negative affects on street handling, so mine is not going back on either.
Old 24-08-2006, 12:19 AM   #8
OED666
OED666's Avatar
it should help with launching... i know brendan mock removed the front sway bar on their eb, and it helped with their 60ft times...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 06:49 PM   #9
Quadcams
Quadcams's Avatar
Like xdclevo, I didn't \0\0???\0\0\0\0??\09e affects on street handling, so mine is not going back on either.
Mate my swaybar is a 30mm whiteline bar atleast 15kg and handling on the street aint to crash hot in these heavy boss powered cars front end rolling around everywhere.
Old 24-08-2006, 06:57 PM   #10
Quadcams
Quadcams's Avatar
Diddnt seem to lift any more than before but just didnt bog down as easly with it on. When on there was a much finer line to getting it right to bogging it (rembering Im a manual).
But honestly mate without spending money your very limited to improving your suspension. Setting up your suspension right can give you some big gains.
Old 24-08-2006, 08:15 PM   #11
Sledgehammer
Sledgehammer's Avatar
Yes it will assist at the drags, but dont try driving on the road without it.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 09:41 PM   #12
northey
How can you not notice the difference driving the car on the street when the front swaybar is removed???
Old 01-09-2006, 01:18 AM   #13
ebxr8240
Performance moderator
ebxr8240's Avatar
It helps both rear wheels bite better...It's not realy a weight saving thing....
Daily driver GTE FG..
