I have seen on these forums that traction control dose not exists on AU XR8 but my Ute when you disconnect the abs module a traction control light comes up on the dash and the car takes off a lot harder with the abs disconnected
MR INCH
maybe you read that it can't be turned off? usually it has a switch to turn it on and off...strange
sorry if im wrong but i always thought XR8's came with LSD standard and you cant have LSD and traction control on the same car....again i most likely m wrong
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
#4 | |||
Tuned by HPF
Not an XR8 but it has both systems. By the way Traction control is a pain in the .... Not worth having. I do have a switch to turn it on or off. Factory setting is always on, I have had mine setup for always off (Can be turned on via the switch). |
not here much anymore
utes never had TC even in BA, i have that light on my dash but thats cos I have a TS50 cluster.
RAM 1500
