Just slidin'
Will V8 injectors fit in a 6. Ie., XR8 injectors in my AUi6, Yes or no.
MD Mondeo - For the family
Yes, tune required
Just slidin'
Stock computer should run 24lb injectors, correct?
The capacity per cylinder is actually greater in the six cyl. When they did the 5.6 stroker they put bigger injectors in. Check the part number thaey are actually same as used in previous six cylinder models 24lbs.
best do some figures i'd reckon. |
#5 | |||
Back on the road
Are you running out of fuel capacity now? How much injector do you need? I think the AU I6 injectors have the jetronic connector where the AU V8 injectors have the USCAR connector. Cheapest option might be just to get an XR6 computer, XR6 fuel rail, and XR6 fuel reg...
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#6 | |||
Back on the road
#7 | |||
#8 | |||
Just slidin'
Its for when the turbo goes on. I have been told by numerous people, even people running 24lb injectors, that no tune will be required. Ill only be using the stock ECU, at the highest boost it will handle (around 6 psi), so I think injectors will be important.There are a few people running the 4 litre on stock computer at 6 psi, and they get around 170-180 kw, so Id say fuel will be an issue. So yes they fit, but you guys say that a tune will be required. Ill be running a rising rate fuel reg, if that makes any difference.
Back on the road
What are the size of std AU i6 injectors...19lb/hr @ 39psi?
I'd be suprised if the std computer would even idle with injectors that are 25% larger than it is programmed for. The "self learning" might be able to account for this a little during cruise, but it will be a pig. Regardless, 24lb/hr injectors are still on the small side for a turbo.... I think you would be better leaving the stock injectors and running an FMU (assuming you want to do this on the cheap). That way inj pulsewidth calculations will still be OK for idle, cruise, and light throttle, and you will only be getting additional fuel when making boost. Vortech FMU's seem to go on eBay 2nd hand for around $100. Where you will be at a disadvantage, compared to the E-Series guys, is that you can't pull any "base" timing from an AU without a chip i.e. there is no distributor that you can rotate to reduce spark across the board. Too much ignition advance is just as likely (even more likely?), too cause pre-detonation with boost than a lean AFR. So in short, you will need a tune to run bigger injectors. But the injectors you are proposing will still be too small, so forget them and just stick with stock injectors and an FMU. Have a think about retarding ignition timing. If you can, rig up an adjustable bracket for the crank trigger pickup so that you can pull a few degrees from base timing.
If you are unsure, get some and give it a go. But I still say you'll need a tune.
Just slidin'
Ok, so another question, and I only ask as I dont know, and I need to learn. How much power at the rear bags will the stock injectors handle?
Will they handle 180 kw safely? Without being on the edge of destruction.
#12 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
Just slidin'
Cool, forgot I asked that question, then proceeded to buy F6 injectors...... We w3ont go there, silly me. Im just going to go to an injector place and see if theyll take a trade on them. Or does anyone here need a set of F6 injectors?
#14 | ||
what are they rated at?
#15 | ||
The Mod Bug Has Hit
Hey mate who are you getting the turbo gear through ya should give snort performance a ring explain the power you wish to have and they should be able to give you your options.
Jake
www.aufalcon.com/jakesfalcon
#16 | ||
Smile
If the f6 injectors are the same as xr6t then theyre good for around 260rwkws at 100% or 230 at 80 odd percent.I am not really sure on the fine details but they are around that much.However they say that they dont suite our sohc heads but the four valve heads like ba..
#17 | ||
Just slidin'
Stuff was bought off a member hear, from snort or a brnad off Snort or something. Its just the parts that dont come with the kits that are a killer.
#18 | ||
Back on the road
F6 injectors are the same size as BA XT injectors aren't they? XR6T and F6 just ran a higher fuel pressure in the rail compared to the n/a engine...I think 4-bar vs 3-bar.
If you put them in your AU with the std AU non-XR reg, then they will not support anywhere near 260rwkw.
#19 | ||
Smile
ba injectors need 50 psi odd of fuel rail pressure to achieve 260rwkws.
#20 | |||
Back on the road
#21 | |||
Back on the road
So those injectors at 58psi will support 260rwkw, then at 39psi they will support more like 170rwkw. Regardless, you will still need to tune the computer someway to account for the larger injector. You've got 2 real options; 1. Buy an FMU, and tune it rich as hell on boost so you dont pop the motor with its std injectors and ignition advance. Cost $150-200 (second hand) 2. Buy a CAPA flash tuner, and some bigger injectors, and safely wind some real boost into the motor. Cost ~$2000 inc injectors and tune. As I mentioned before, this is safer to do on EA-EL (excluding EF), because you can pull some ignition advance as well.
#22 | ||
Just slidin'
I think Ill end up going the flash tuner route, but that means it will be a longer process. Keeping in mind I only want around 180-200kw MAX, will a unichip be able to be tuned for it?
#23 | ||
horsepower
monty, I did alot of research regarding a unichip system , and yes they can tune it to run properly with additional parts (extra module) to be exact which will increase the maps in unichip for timing and fuel mapping.
But i was told the unichip system cant read boost , so in other words it's only fuel mapping and ignition timing that will be done to make the turbo run okay but it will support safely to about 180rwkw on std injectors. Ask spiro at autotech , he told me the could do it. |
#24 | ||
Just slidin'
Cheers mate. Will try and chat too him.
