CRE.87V
hey all still probs with the au
oil pressure light is still coming on at lights...oil pressure is perfect..switch is new smell of coolant...just had it flushed and filled....no leaks at all going around corners or roundabouts feels like the car wants to slide out...same while hitting bumps car pulls to left or right when slowing down in gear using no brake.....it surges until i come to a halt surging still while 1st into 2nd....ran diagnoses check on it....fuel pump is fine...some error codes came up...was unsure if they were past probs or new ones....map sensor....going to check in few days again..if there are no probs i got told they are injectors??? would it be cheaper to put in rebuilt ones or just clean mine cheers all burley |
Are you sure about that?
V8 or I6?
Manual or Auto? Series? |
CRE.87V
99 series 1 xr6 vct 5 speed
i had a coolant smell too but the leak was so slow you didn't notice it look carefuly for any slight white crusty substance mine was a radiator tank with a slight leak at the seal it was in a hard to see spot so took me ages to find (months)
